kc717
Nov 26, 2022Follower
How do I set up 2 xbox's using seperate live accounts on a xr500?
Looking for a way to connect 2 xbox one's using separate live accounts to e able to play online games at the same time. Using a XR500 with updated frmware. Thank you
Nov 26, 2022Guru - Experienced User
Just connect them. WIred or WIreless. Refer to the MS or xbox support pages for help and information on connecting game consoles to the router.
I recommend setting NAT Filter to OPEN on the XR router. Under Adavanced tab/WAN Setup.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
