FLJDesign
Dec 01, 2021Initiate
How do I transfer my IoT devices from a Linksys router to the Netgear XR1000?
The XR1000 was not in the list. Good day, I have the Linksys wrt1900AC, about 20 IoT devices installed on Google home, laptop and desktop and a repeater. Recently I added IPTV with an Android b...
- Dec 01, 2021
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routersAs long as you use the same SSID and password from the prior router on the this router, your devices should auto reconnect.
Thank you.
Dec 01, 2021Guru - Experienced User
Thank you.
- Netduma-FraserDec 02, 2021NetDuma PartnerAs above, yes that should work just fine
- FLJDesignDec 02, 2021Initiate
Thank you all.
...most of my IoT WiFi LED light, outlet switches etc...works fine after the transfer. Only the Google mini and the Google display lost the network connection. I had to re-enter the same SSID and password.
It was minimum effort. Thank you
- FURRYe38Dec 02, 2021Guru - Experienced User
Enjoy.
