TTedd
Feb 22, 2020Aspirant
How do the various QOS settings limit speed to devices?
Question to all. Manual and web does not seem to answer the following questions clearly. How does share excess on/off work - what is the "excess"? Here is what I interprate I am seeing... and...
Netduma-Fraser
Feb 22, 2020NetDuma Partner
Did you disable Share Excess for both download and upload? As there is a button for each. Have you changed Traffic Prioritization at all as that would supersede the Anti-BB/Allocation.
- TTeddFeb 22, 2020Aspirant
Thanks for response. Learned something new... share excess has two places it needs to be set/unset. Always thought it was universal setting for both uploads and downloads. I suspect this explains what I was seeing. The QOS defaults to UPLOAD view and I set share excess to OFF and I was viewing DOWNLOAD behavior. Menu and manual would do well to highlight this in a better way e.g. Share excess button for both upload and download shows in the menu view.
- Netduma-FraserFeb 22, 2020NetDuma PartnerGreat! We will be making that a lot more user friendly in our next update.
