cattortoise
Dec 22, 2021Tutor
How do you disable WPS on XR450 Nighthawk Router?
I am trying to disable WPS on a XR450 Nighthawk Router, but I do not see an option to do so. The only WPS settings I see is through the 'WPS Wizard' section. Where is this setting located?
Netduma-Fraser
Dec 28, 2021NetDuma Partner
I responded to your other topic: I believe if you have Smart Connect enabled then WPS is disabled, if you don't then there is no specific way to disable it as far as I am aware.
