nonnumericdave
Apr 14, 2018Initiate
How do you whitelist MAC addresses on the XR500
I just purchased the XR500, and after performing the basic setup, I'm trying to figure out how to whitelist MAC addresses. I see I can blacklist a MAC address from the "Device Manager", but that is ...
- Apr 14, 2018
ACL was removed in the latest firmware, I believe it had some stability issues. MAC address filtering provides no real security, rather like hiding your SSID, but it does provide a false sense of security in my view. It is so easy to spoof by someone using say kali linux and Wireshark for instance. There are even videos on youtube to show how to do it! You really are better off using something like a 8-16 character ASCII WPA2 password. Also some operating systems use MAC address randomisation, like Apple for instance and MAC filtering can actually make connection to the router more problematic.
Killhippie
Apr 14, 2018Prodigy
