Blarn_Kranston
Mar 22, 2022Apprentice
How many IP address reservations on XR1000/DumaOS 3.0? Device names randomly changing?
Good day all! I am attempting to account for all my devices on my network and name them, and also reserve IP addresses for many of them I would like to remain static. I am running into 2 issues....
Netduma-Fraser
Mar 22, 2022NetDuma Partner
If I remember rightly someone did have this issue before and I manually added static IPs until I couldn't and I think 17/18 was the maximum. Where are you setting the names exactly? We usually suggest doing this in the Device Manager - the Settings part may see the original name.
- Blarn_KranstonMar 22, 2022Apprentice
Thanks Fraser,
I think my issue w/ the names was due to the fact that i was naming the devices on the same page as the IP reservations. Technically, this does work, as I saw changes when I looked in the device manager tab afterwards. However, I think when the IP reservation was over-ridden when you added the 18th one, the name of the device that you added in the deleted reservation was also removed from device manager.
Are there any plans to raise the number of reservations are able to create?
- Netduma-FraserMar 22, 2022NetDuma PartnerUnderstood! That would be a decision for Netgear as it's part of their settings so not something we have direct influence over unfortunately.
