droesw's avatar
droesw
Guide
Jul 22, 2019
How should I set QoS speed if I get higher than what I pay for.
I'm wondering what speed exactly I should set my QoS to. On average I get 215 mbps download and about 12 mbps upload. My ISP is spectrum and I only pay for my speeds to be 200/10. How should I set the QoS speeds? Should I have it set to 215/12 or 200/10?
1 Reply
  • I would reccomend setting the QoS speeds to what you actually get. You basically want to make it so that when you turn down the Anti-Bufferbloat slider, the bandwidth shown next to the slider will be what comes up when you do a speedtest.
