EnVy_Hype
Jan 14, 2019Aspirant
How to change channel width on xr500 in china?
Signal strength isn't that good, can't even acess the 2.4ghz channel in the bathroom(right next door). I am currently using channel 1 and 161. Is there any way of making the signal better, my netgear...
Netduma-Fraser
Jan 15, 2019NetDuma Partner
You could disable 20/40MHz coexistence in Settings > Advanced WiFi Settings which would force it to just use 40MHz. More likely there are devices surrounding the router operating wireless that are interfering could be a phone, wireless headset etc, even a microwave so move anything like that away from the router at least 3 feet
