Ivy07
May 30, 2021Follower
How to change the default ftp username and password?
The default setting is 'admin' and 'password'. I did not find any option for changing them.
Netduma-Fraser
May 30, 2021NetDuma Partner
The username can't be changed but you would have been given the opportunity to change the password during the setup wizard, alternatively go to Settings > Administration > Set Password and you can change it there
