Tlapts
May 11, 2020Follower
How to create hidden network on XR300
Is there a way to turn my XR300 WiFi SSID's into hidden networks?
Thanks
Ed @ tlapts3527@gmail.com
You might see if there is a disable SSID broadcast feature under advanced settings. If not, then the SSID can't be hidden.
- Netduma-FraserNetDuma PartnerAs above, that is the only way you could do it.
