ltskynet
Apr 19, 2020Follower
How to disable access control on Netgear Nighthawk XR450
Hi Everyone, I have problem setting up my google home mini with my new router Netgear Nighthawk XR450, basically I need to 1.Disabling Access Control.(cannot disable no option for me) 2.Enablin...
Apr 20, 2020Guru - Experienced User
The XR series doesn't have Access Control features.
There is some blocking configuration settings: Pg 72
https://www.downloads.netgear.com/files/GDC/XR500/XR500_UM_EN.pdf
- Netduma-FraserApr 21, 2020NetDuma PartnerAs above, that option isn't available. What issue are you encountering preventing a successful connection?
