Sandwich
Jun 19, 2019Tutor
How to disable QoS
How do I disable the QoS function on this equipment? I cant find the option to disable it. It seems to have been more trouble than its worth. I keep getting random ping spikes and packet loss in 2 dif...
Sandwich
Jun 19, 2019Tutor
Nevermind, figured it out. Thank you.
- Netduma-FraserJun 19, 2019NetDuma PartnerI would not advise disabling QoS, that will make it worse. I would suggest you follow this guide while saturating your connection and trying different Anti-Bufferbloat percentages to see what minimises the spikes/ping the most: http://support.netduma.com/en/support/solutions/articles/16000074717-diagnose-modem-internet-service-provider-issues
- SandwichJun 19, 2019Tutor
Ok! I'll do some troubleshooting with it when I get home.
