Sandwich
Jun 19, 2019Tutor
How to disable QoS
How do I disable the QoS function on this equipment? I cant find the option to disable it. It seems to have been more trouble than its worth. I keep getting random ping spikes and packet loss in 2 dif...
Netduma-Fraser
Jun 19, 2019NetDuma Partner
Yeah QoS off is a bad idea, if you follow that guide to optimise Anti-Bufferbloat you should be good. Take a look at this also to try the other QoS settings: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Sandwich
Jun 19, 2019Tutor
We had a ton of people visiting due to an event we held at home this weekend but a large majority of those people are gone. I'll go through and take them completely off the network if I need to though.
