cattortoise
Dec 22, 2021Tutor
How to disable WPS?
I am trying to disable WPS on a XR450 Nighthawk Router, but I do not see an option to do so. The only WPS settings I see is through the 'WPS Wizard' section. Where is this setting located?
Netduma-Fraser
Dec 23, 2021NetDuma Partner
I believe if you have Smart Connect enabled then WPS is disabled, if you don't then there is no specific way to disable it as far as I am aware.
cattortoise
Dec 28, 2021Tutor
I dont think that really disables it. I have Smart Connect enabled and when I connect to my WiFi using a new device, I get a message saying to enter the password OR press the button on my router. Its pretty disappointing that Netgear does not give the option to disable such a feature, especially since its such a poor security standard (and security issue).
- Netduma-FraserDec 29, 2021NetDuma PartnerI'll request that Netgear adds that ability for you but it's not a guarantee they will do so
