HailLordMidas's avatar
Jun 09, 2022
how to fix Uncaught TypeError: $(...)[0].getApp
So I noticed that my XR1000 would disconnect from my internet whenever my Xbox and pc were on at the same time. They are both hardwired and at first I thought the XR1000 was updating when it happen the first time but after the second and third I decided to try logging into the DumaOS and that's when I started to get the error code. My question is how to fix it? I've factory reset it and I still continue to get the error code.
  • Does this occur literally as soon as you boot them both or just at some point?
    Can you check the logs in System Information when the problem occurs and see if there are any more informative entries than this?
    • HailLordMidas's avatar
      HailLordMidas
      After doing some testing I found out it only happens when my pc is turned on. I’ve even downgraded and it still disconnects but the error message is gone and I can log into DumaOS. In the logs the only thing I see is multiple [Dos attack: RST SCAN] along with ACK Scan and Fraggle Attack. Also to add it usually drops the connection after about 15mins sometimes sooner.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        That's very strange, what is your PC model/operating system? Have you made any manual connection settings on the PC itself? Is there anything you do every time on the PC within the first 15 minutes of it being on?
