tech50
Jul 19, 2021Follower
how to fix xr500 to connect to internet
My expiernce with my XR500 netgear nighthawk gaming pro router was a storm that knocked out my router's connection to the internet. How do you fix this problem?: Problem solution i came up with was u...
Netduma-Liam
Jul 20, 2021NetDuma Partner
If you hook the XR500 back up again, I suspect you'll probably have connectivity again unless there was some damage caused by the storm. If you have any further issues let us know.
