PEJMAN's avatar
PEJMAN
Tutor
Oct 15, 2022
how to get ONLY security updates for XR500 whitout DummaOS 3.0
Hi
I wondering if possible to get only security vulnerability update for XR500?
my XR500 works great with firmware Version 2.3.2.114, but works worst with firmware Version 2.3.2.134 almost my XR500 being like a unusable black box on the table and i losing connection constantly and i have fiber connection in Sweden/Stockholm and i had support guy in my home too and he said it is not fiber issue and he test with there own router and worked without problem and in router some settings don´t get saved any more and i have hard reset firmware many times and tried all firmware from 2.0.0.28 to 2.3.2.134 the ONLY firmware works is 2.3.2.114 but my issue is the security vulnerability updates and i really don´t want that new futures on DumaOS 3.0 because this OS is very big size for this XR500 router, i just asking if it is possible to get that updates? before i buying new router from another company and never buy Netgear products anymore.
1 Reply
  • There isn't a way to have the security updates separately. Some updates may just have security updates done like .114 and others may include other fixes/features with security updates.
    I'd suggest upgrading to the latest and then letting us know exactly the issues you're getting and what you've tried to do to resolve the issues and we can go from there. The above is false, the router hasn't been abandoned, you can keep track of firmware progress here: https://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress
