_GG_
Aug 22, 2020Aspirant
How to get open nat type on my Xbox one x with NETGEAR nighthawk pro xr500
To start I have xfinity as my internet provider when I have it connected to my Xbox one x with an Ethernet I can see that under the Xbox settings it says open nat type and when I play a game for examp...
Netduma-Fraser
Aug 22, 2020NetDuma Partner
What is your Xfinity router/modem model? You most likely need to put the WAN IP from the XR500 System Information page into the DMZ on the Xfinity router. Then you should get an Open NAT.
_GG_
The xfinity modem model is TG1682G, also want to make sure if the cabling is from xfinity modem > NETGEAR router > Xbox, all connected using Ethernet if that’s how it goes.
- Netduma-FraserAug 23, 2020NetDuma PartnerThank you, okay so it is a gateway which means you should do the WAN IP into DMZ suggestion I made above and you should get an open NAT then.
- _GG_Aug 23, 2020AspirantMy wan ip is 10.0.0.182 on my internet status on the DUMA OS dashboard from the NETGEAR And I put that wan ip 10.0.0182 in the DMZ page on my xfinity router. It came up as double nat detected and nat type strict on my Xbox.
- Netduma-FraserAug 23, 2020NetDuma PartnerReboot both the Xbox and XR500 and it should work.
