hboutlaw77
Feb 18, 2024Follower
how to get past initial dumaos screens
I've setup my netgear router using the dumaos setup wizard. It's stuck in this loop to prioritize gaming or not. I cannot get past these screens to the desktop and configuration setup screens. I've...
Netduma-Fraser
Feb 18, 2024NetDuma Partner
Which router is it you're using exactly? Use another device to access and see if you can get past that point
- hboutlaw777Feb 18, 2024Aspirant
ax5400 don't have another computer with an ethernet port.
I did clear the cache and used a different browser
- Netduma-FraserFeb 18, 2024NetDuma PartnerThe XR1000? You can use WiFi, can you provide a screenshot of the exact point you're stuck at please?
Resolved...using Edge browser. crazy
- FURRYe38Feb 21, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
