Blaster213
Aug 18, 2020Aspirant
How to open ports or port foward on the XR700
Hello how do you port foward or allow ports on the rx700
- This should give you some steps, it shouldn't be necessary to use though. May be easier to switch NAT to open in WAN Settings.
https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
1 Reply
- Netduma-FraserNetDuma PartnerThis should give you some steps, it shouldn't be necessary to use though. May be easier to switch NAT to open in WAN Settings.
