haoblue
Jun 20, 2022Aspirant
How to remove live parental setting and disable OpenDNS?
My router model is XR 700.
Right now, I have a headache with the previous settings by Netgear Genie. I know Netgear Genie had retired; yet, its previous settings on are still effective for my r...
Netduma-Fraser
Jun 20, 2022NetDuma Partner
Do a factory reset, that will wipe any previously saved settings and you should be good to go then.
