fivestar047's avatar
fivestar047
Follower
Aug 27, 2023
How to remove them automatically ?
50 devices are used | They have to be deleted after a few days | Otherwise, the rapp becomes inactive | Very bad experience
1 Reply
  • I can't see your image until it has been moderated, is it the Device Manager? If you give your devices static/reserved IPs it should happen less
