SakHatesLag
Nov 07, 2021Aspirant
How to revert from DumaOS?
Hello, I'm looking how to revert back to standard NetGenie firmware on my XR300. I don't want to use DumaOS anymore, I want to use a third-party firmware as I believe they will be better since I...
Nov 07, 2021Guru - Experienced User
I don't have the XR300 to compare with but I wasn't aware it every had stock netgear firmware on it without dumaOS. I have seen 3rd party options for flashing it but you won't find that on the official forums.
SakHatesLag
Hello, I am unaware of how to because the file type required for flashing is .chk
but every firmware update I find does not fit this file. I just need to know if it’s possible to revert to stock firmware. I can’t find anything on it so I’m kinda doubting it’s possible at this point.
