jdashca
Apr 25, 2021Aspirant
How to see which devices connected to XR1000 are using Wi-Fi 6 (802.11ax)?
How do I determine which devices connected to my XR1000 are using Wi-Fi 6 (802.11ax)? I'm trying to troubleshoot and see which supposedly Wi-Fi 6 certified deives are actualy using that protocol.
Apr 25, 2021Guru - Experienced User
look at their link speeds. an AX device is going to have a faster link speed.
they aren't going to show 'yes, connected using wireless 6"
Its just going to have a higher potential connection link.
Wifi 6 isn't that much faster of a protocol but it does support higher concurrent usage.
- jdashcaApr 25, 2021Aspirant
How do you look at an individual device's link speed?
- plemansApr 26, 2021Guru - Experienced User
One the device itself. Not sure about iOS but on android/windows, you can check your wireless connection stats.
- jdashcaApr 26, 2021Aspirant
Unfortunattely, iOS doesn't make such information available.
What i really want is for the NetGear XR1000 router to tell me which devices are connected using which protocol (Wi-Fi 5 (802.11 ac), Wi-Fi 6 (802.11ax), etc.) and frequency.
