Anirban
Jul 11, 2020Aspirant
How to setup ExpressVPN on Nighthawk Pro Gaming XR500 ?
Hi, I am gonna get ExpressVPN but can anyone tell me how to install ExpressVPN on my Nighthawk Pro Gaming XR500 router ?
Netduma-Fraser
Jul 11, 2020NetDuma Partner
You'll need to obtain the OpenVPN configuration file from them, then you can paste it into the advanced section of VPN Setup.
- AnirbanJul 11, 2020AspirantBut doing so will it void my routers warranty or not ?
- Netduma-FraserJul 11, 2020NetDuma PartnerNo of course not, it's a feature on the router, we wouldn't implement anything that would void the warranty.
- AnirbanJul 11, 2020AspirantThank you for that info :) BTW can you tell me if I use ExpressVPN , can I use GEO-FILTER then ?
