Anirban
Jul 11, 2020Aspirant
How to setup ExpressVPN on Nighthawk Pro Gaming XR500 ?
Hi, I am gonna get ExpressVPN but can anyone tell me how to install ExpressVPN on my Nighthawk Pro Gaming XR500 router ?
Netduma-Fraser
Jul 11, 2020NetDuma Partner
You'll need to obtain the OpenVPN configuration file from them, then you can paste it into the advanced section of VPN Setup.
Anirban
But doing so will it void my routers warranty or not ?
- Netduma-FraserJul 11, 2020NetDuma PartnerNo of course not, it's a feature on the router, we wouldn't implement anything that would void the warranty.
- AnirbanJul 11, 2020AspirantThank you for that info :) BTW can you tell me if I use ExpressVPN , can I use GEO-FILTER then ?
- Netduma-FraserJul 11, 2020NetDuma PartnerYes you should still be able to use the Geo-Filter when behind the VPN.
