Lashn
Sep 28, 2018Aspirant
How to setup XR500 efficiently with Fritzbox 7560 Modem
I have an XR500 connected to the back of my Modem (FRITZ BOX 7560) and it isn't really making much difference i still ping spike up past 100-150ms even with ther outer running! The router is connecte...
Netduma_Jack
Sep 28, 2018NetDuma Partner
Hi Lashn,
When are you seeing these ping spikes and how are you measuring this? It's possible you have a general problem with your line, so I recommend you run a PingPlotter test and post your results here so we can take a look at them. Here's a quick guide on how to do this: http://forum.netduma.com/topic/23881-ping-plotter-quick-guide/
As for the XR500 itself, I recommend you follow our optimal settings guide to make sure each feature is setup as good as it can be for your connection: http://support.netduma.com/support/solutions/articles/16000077071-dumaos-optimal-settings-guide-accessing-dumaos-step-1-
Thanks,
Jack
