Lashn
Sep 28, 2018Aspirant
How to setup XR500 efficiently with Fritzbox 7560 Modem
I have an XR500 connected to the back of my Modem (FRITZ BOX 7560) and it isn't really making much difference i still ping spike up past 100-150ms even with ther outer running! The router is connecte...
Sep 28, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
