Godrik
May 18, 2019Aspirant
How to test if Hybrid VPN is working for "Only VPN these Services"
I was able to successfully set up my VPN Provider under Hybrid VPN on my XR700.
I only want to use the VPN for torrents. I was able to add my PC under the "VPN Traffic" tab, and I selected "Onl...
schumaku
May 19, 2019Guru - Experienced User
Sniffing for suspect traffic on the WAN side of the router on the ports/protocol your torrent software is active on.
- GodrikMay 19, 2019Aspirant
What is "sniffing" and how do I do it? What does WAN side mean?
- Netduma_AlexMay 20, 2019NetDuma Partner
How did you figure out which ports your torrents are using?
You can usually set which ports you want your torrent software to use from within the software itself, so check inside the software that the selected port matches what you put in your VPN.
- GodrikMay 20, 2019Aspirant
Yes, I went into the uTorrent app settings and took note of the ports it uses.
From that point of view it should be properly routing my torrent traffic via the VPN (and I'm sure I have the VPN properly configured from within the Duma OS).
I was just wondering how I might be able to test and verify that that is indeed what is happening.
