Godrik
May 18, 2019Aspirant
How to test if Hybrid VPN is working for "Only VPN these Services"
I was able to successfully set up my VPN Provider under Hybrid VPN on my XR700.
I only want to use the VPN for torrents. I was able to add my PC under the "VPN Traffic" tab, and I selected "Onl...
Godrik
May 19, 2019Aspirant
What is "sniffing" and how do I do it? What does WAN side mean?
Netduma_Alex
May 20, 2019NetDuma Partner
How did you figure out which ports your torrents are using?
You can usually set which ports you want your torrent software to use from within the software itself, so check inside the software that the selected port matches what you put in your VPN.
- GodrikMay 20, 2019Aspirant
Yes, I went into the uTorrent app settings and took note of the ports it uses.
From that point of view it should be properly routing my torrent traffic via the VPN (and I'm sure I have the VPN properly configured from within the Duma OS).
I was just wondering how I might be able to test and verify that that is indeed what is happening.
- Netduma_AlexMay 21, 2019NetDuma Partner
One easy way to find out:
Routing traffic through VPN usually introduces a bandwidth cap which is lower than your connection's maximum. Are your torrents going slower than they would be if they weren't on VPN? Maybe compare the speeds with the VPN rule activated and deactivated? If the speeds change when you change the rules, it shows that they're having an effect.
