Profaniter
Jul 16, 2019Tutor
How to Use it
So I have some questions. Before buying the router, I'd like to hear some experienced inputs from you guys. 1. When connecting console (for my case, PS4 Pro) to the Pro Gaming router XR500, afte...
Profaniter
Jul 16, 2019Tutor
For answer #1, thank you! I'll keep that in mind!
for #2, so would this mean I could still be able to use Wifi while setting it in AP mode? I was thinking of turning off Wifi on the XR500, but leave Wifi on Orbi, so you're suggesting I should set it in AP Mode then?
Netduma_Alex
Jul 16, 2019NetDuma Partner
You could leave the orbi in it's usual mode and just put the orbi's IP address into the DMZ of the XR500, then turn off the wi-fi on the XR500... Maybe that's wrong? Let me know FURRYe38
