dc2018
Jul 15, 2019Tutor
Huawei Mate SE smartphone doesn't see Wi-Fi networks from Netgear XR500 router
I'm using this Netgear XR500 router for most of my Wi-Fi devices (laptops, desktops, iOS iphone & iPad, etc.) But when I was testing my other smartphone, Huawei Mate SE, it doesn't see the Wi-Fi net...
- Jul 17, 2019In advanced WiFi settings disable MU-MIMO & HT160. It may be that the phone doesn't support these and therefore can't see the network while they are enabled.
Netduma_Alex
Jul 16, 2019NetDuma Partner
The Huawei Mate SE only supports 2.4GHz, but Smart Connect should allow it to connect properly. As a test, could you disable Smart Connect and see if the 2.4GHz network is visible? If this works, a good temporary measure might be to use the router's Guest Network function to create a seperate 2.4GHz only network just for your phone to connect to.
- dc2018Jul 16, 2019Tutor
That's what I tried to do after I posted it. After disabling it (it kicked me off my main PC that I'm using to post this, so this caused some additional issues) but the Mate SE still didn't see any Wi-Fi networks without Smart Connect. It's only when I plugged in my old LinkSys router that smartphone was able to connect to it. So what could be the issue here?
- Netduma-FraserJul 17, 2019NetDuma PartnerIn advanced WiFi settings disable MU-MIMO & HT160. It may be that the phone doesn't support these and therefore can't see the network while they are enabled.
- dc2018Jul 20, 2019Tutor
Yes, thanks. Disabling "MU-MIMO" was the solution. "HT160" (whatever that is) was already unchecked.
But now I'm wondering, what am I going to miss without that "MU-MIMO" setting on my other devices?
