dc2018
Jul 15, 2019Tutor
Huawei Mate SE smartphone doesn't see Wi-Fi networks from Netgear XR500 router
I'm using this Netgear XR500 router for most of my Wi-Fi devices (laptops, desktops, iOS iphone & iPad, etc.) But when I was testing my other smartphone, Huawei Mate SE, it doesn't see the Wi-Fi net...
- Jul 17, 2019In advanced WiFi settings disable MU-MIMO & HT160. It may be that the phone doesn't support these and therefore can't see the network while they are enabled.
dc2018
Jul 16, 2019Tutor
That's what I tried to do after I posted it. After disabling it (it kicked me off my main PC that I'm using to post this, so this caused some additional issues) but the Mate SE still didn't see any Wi-Fi networks without Smart Connect. It's only when I plugged in my old LinkSys router that smartphone was able to connect to it. So what could be the issue here?
Netduma-Fraser
Jul 17, 2019NetDuma Partner
- dc2018Jul 20, 2019Tutor
Yes, thanks. Disabling "MU-MIMO" was the solution. "HT160" (whatever that is) was already unchecked.
But now I'm wondering, what am I going to miss without that "MU-MIMO" setting on my other devices?
- Netduma_AlexJul 22, 2019NetDuma Partner
Any MU-MIMO compatible devices may go a tiny bit slower than they would have done had MU-MIMO not been disabled.
