Brainbleach
Sep 20, 2019Star
Hybrid-VPN DNS leaks
I'm having an issue trying to setup a hybrid-vpn connection on my xr500. I can get the VPN to work but the router still uses my DNS servers setup for my normal connection. In this case it's googles...
Sep 20, 2019Guru - Experienced User
You can manually set custom DNS under Setup/Internet.
Brainbleach
Sep 20, 2019Star
Yes but how does one use the DNS server provided by the VPN service with the VPN connection but use my "regular" DNS servers for my non-VPN traffic?
- Netduma-FraserSep 21, 2019NetDuma PartnerWhat are you trying to apply the VPN to specifically? Could you provide a screenshot of your entire VPN page please?
