RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
LevelUpLiam24
Apr 20, 2019Apprentice
Hey all, question for you regarding expressvpn and the xbox via the XR500.
I spoke with expressvpn support because the xbox is the only device experiencing issues since setting up via HybridVPN. The issue is moderate NAT.
ExpressVNP support said "I think the issue is because you're using a two Nats. Please note that when you're using a VPN, you go through our networks which leads to another NAT which makes it moderate or in some cases strict. (Good thing, we don't provide Nat Firewalls) and then another NAT on your router."
Does anyone know an issue to resolve this? I'm sure there are gamers that use VPN services and have an open NAT, I've read of people that use a VPN specifially to achieve open NAT.
Any help is greatly appreciated.
