RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
LevelUpLiam24
Apr 20, 2019Apprentice
Hey all, question for you regarding expressvpn and the xbox via the XR500.
I spoke with expressvpn support because the xbox is the only device experiencing issues since setting up via HybridVPN. The issue is moderate NAT.
ExpressVNP support said "I think the issue is because you're using a two Nats. Please note that when you're using a VPN, you go through our networks which leads to another NAT which makes it moderate or in some cases strict. (Good thing, we don't provide Nat Firewalls) and then another NAT on your router."
Does anyone know an issue to resolve this? I'm sure there are gamers that use VPN services and have an open NAT, I've read of people that use a VPN specifially to achieve open NAT.
Any help is greatly appreciated.
Netduma-Fraser
Apr 21, 2019NetDuma Partner
I would suggest you ensure the XR500 is in the DMZ of the upstream modem/router or the hub is in modem mode. Put the console in the XR500 DMZ mode and that will help with NAT. Also disable the Geo-Filter fully before boot up. Does that resolve your issue? How are you measuring NAT by the console network settings or the game reading?
- LevelUpLiam24Apr 21, 2019ApprenticeWith a few hours support we still couldn't get this resolved and honestly I think it was due to expressvpn not enabling port forwarding on their end. I decided to check out purevpn especially since it's native with the firmware. However, there isn't any support for the ddos dedicated IP? Is there any plans to implement this? Also you have to purchase the port forwarding addon to ensure open NAT.
Still new to using a VPN for gaming, so I'm open to suggestions if anyone has any.- Netduma-FraserApr 21, 2019NetDuma PartnerNot sure what you mean regarding DDoS dedicated IP, that's not a Netgear feature or a router feature I'm aware of. That's for PureVPN? Might be worth looking into a gaming VPN that might do that by default, only one I can think of is VyprVPN
- schumakuApr 22, 2019Guru - Experienced User
LevelUpLiam24 wrote:
With a few hours support we still couldn't get this resolved and honestly I think it was due to expressvpn not enabling port forwarding on their end.All these hide-my-a** VPN providers are doing many2one NAT on their end, and won't assign a public IP exclusively per VPN session - thus no explicit port ... how would you control it?
