RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
Netduma-Fraser
Apr 21, 2019NetDuma Partner
I would suggest you ensure the XR500 is in the DMZ of the upstream modem/router or the hub is in modem mode. Put the console in the XR500 DMZ mode and that will help with NAT. Also disable the Geo-Filter fully before boot up. Does that resolve your issue? How are you measuring NAT by the console network settings or the game reading?
LevelUpLiam24
Apr 21, 2019Apprentice
With a few hours support we still couldn't get this resolved and honestly I think it was due to expressvpn not enabling port forwarding on their end. I decided to check out purevpn especially since it's native with the firmware. However, there isn't any support for the ddos dedicated IP? Is there any plans to implement this? Also you have to purchase the port forwarding addon to ensure open NAT.
Still new to using a VPN for gaming, so I'm open to suggestions if anyone has any.
