RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
chaoticbeliever
Apr 30, 2019Aspirant
Launch a web browser from a computer or mobile device that is connected to your router’s network.
Enter www.routerlogin.net.
A login window displays.
Enter the router user name and password.
The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
The Dashboard displays.
- Click Settings > Advanced Settings > VPN Client.
- Select the Enable VPN Client check box.
- Select your VPN provider (eg. Ivacy VPN) from the VPN Server drop-down menu.
- Select the VPN protocol, country, and city that you want to use for your VPN connection.
- Enter the user name and password provided by your VPN service provider.
- Click the Connect button to connect to your VPN service.
- Your VPN service is enabled.
maallen
May 15, 2019Aspirant
Hi,
I have my HybridVPN setup with NordVPN, everything works as expected however sometimes the connection will fail after a period of time and I'm required to login to the router interface and disable and then re-enable HybridVPN which gets the connection back up & running. Is it possible for the router to do this automatically if an active VPN connection drops out?
- Netduma-FraserMay 15, 2019NetDuma PartnerNot exactly, you have the option to block traffic if the VPN disconnects so you can then connect to a different server to re-establish the connection. I don’t believe it will do this for you. How long is it before the connection drops? Does it consistently do this and same time frame each time?
- dglsmcd_USMCMay 23, 2019Luminary
maallen, distance (read ping) and server load are important to maintain a steady and fast VPN. For NordVPN go to this link: https://nordvpn.com/servers/tools/. Click on advanced options to tailor the type of VPN connection that you want and it should give you a recommneded server based on the NordVPN algorithm-this can and will change based on the above factors. You may have to experiment with different servers to find the best connection for your location. Hope this helps.
- Juni0rM1ntJul 10, 2019Aspirant
Gents,
Is Hybrid VPN availabe for PIA subscribers?
Thank you!
-JM
- Netduma-FraserJul 10, 2019NetDuma PartnerYou can use Hybrid VPN with any provider as long as you're able to obtain the OpenVPN config files from them. Then you can input it into the advanced section of the feature, enter your login details and it'll work.
