RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
maallen
May 15, 2019Aspirant
Hi,
I have my HybridVPN setup with NordVPN, everything works as expected however sometimes the connection will fail after a period of time and I'm required to login to the router interface and disable and then re-enable HybridVPN which gets the connection back up & running. Is it possible for the router to do this automatically if an active VPN connection drops out?
dglsmcd_USMC
May 23, 2019Luminary
maallen, distance (read ping) and server load are important to maintain a steady and fast VPN. For NordVPN go to this link: https://nordvpn.com/servers/tools/. Click on advanced options to tailor the type of VPN connection that you want and it should give you a recommneded server based on the NordVPN algorithm-this can and will change based on the above factors. You may have to experiment with different servers to find the best connection for your location. Hope this helps.
- Juni0rM1ntJul 10, 2019Aspirant
Gents,
Is Hybrid VPN availabe for PIA subscribers?
Thank you!
-JM
- Netduma-FraserJul 10, 2019NetDuma PartnerYou can use Hybrid VPN with any provider as long as you're able to obtain the OpenVPN config files from them. Then you can input it into the advanced section of the feature, enter your login details and it'll work.
- dglsmcd_USMCJul 27, 2019Luminary
Juni0rM1nt, the OpenVPN config files are often buried within the VPN providers website. In the case of PIA, here is a link for their OpenVPN config files based on 256 bit encryption (strongest): OPENVPN CONFIGURATION FILES (STRONG). Copy and paste the entire config file to the configuration field under the advanced tab of Hybrid VPN. Be sure and select the config file from the state in which you currently live-this should maximize your performance (read lower ping/latency). Hope this helps.
- tfbitAug 16, 2019Tutor
I installed the new V2.3.2.56 firmware last night and decided to try our the Hybrid VPN stuff. I have NordVPN and have been using their Windows app and it's been working great, showing no problems when checked at ipleak.net. When setting up the Hybrid VPN I had no problem adding a NordVPN configuration file, getting logged in, and connected. However now when checking with ipleak.net it shows that my IP address is the correct NordVPN address but now shows all my isp's DNS servers instead of the single NordVPN DNS server I see using the Window application. I saw another person, RaleighEd, at the start of this thread mentioning leak issues and then Netduma_Jack saying that if his leaks were DNS leaks that it was a known issue and it would be fixed in a future firmware release. Is this still an issue?
Thanks!
Todd
