RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
Lm60
Jan 03, 2020Aspirant
Hi,
I have it setup and working but my problem is when I turn the vpn on I get double Nat on the Xbox. It’s only when the vpn is on. Not sure what is causing this?
Thanks for your help
Luke.
Luke.
Netduma-Fraser
Jan 04, 2020NetDuma Partner
Hi Luke, that's down to the VPN, they may block ports that are required for an Open NAT. May be worth looking for a gaming VPN or asking them if they can unblock ports on servers your account uses.
