RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
Netduma-Fraser
Apr 21, 2020NetDuma Partner
Does it occur on all games you're playing? Are you using the Geo-Filter at the same time?
