RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
rbroz73
Sep 08, 2020Tutor
Has anyone got IPVanish VPN to work with the XR500?
Netduma-Fraser
Sep 09, 2020NetDuma Partner
Are you using the IPVanish OpenVPN configuration files?
