RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
rbroz73
Sep 08, 2020Tutor
Has anyone got IPVanish VPN to work with the XR500?
dglsmcd_USMC
Sep 10, 2020Luminary
The configuration files for ipvanish can be found here:
https://www.ipvanish.com/software/configs/?_ga=2.61144676.939145539.1599761612-1299560907.1599761612
Download configs.zip to download all the available config files or pick the one that is best (closest) to your physical location:
https://www.ipvanish.com/software/configs/configs.zip
