RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
Cryp1ic
Jan 13, 2021Aspirant
Hello, I need big help trying to figure out setting up my vpn with the xr500 I spent 5 hours last night trying to get it to work and I’m completely lost. I am not a networking guy at all. I tried my best but you all got me confused as hell with this download the config file and all that. Lol. I need help. I am going to provide a screenshot of the instructions I think I’m supposed to use and my current situation.
- Netduma-FraserJan 13, 2021NetDuma PartnerCryp1ic you're using the VPN service feature rather than the Hybrid VPN feature. What is your reason for trying to use a VPN? Then I can point you in the right direction.
