RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
JoeFI
Jan 14, 2021Apprentice
Hi,
I'm trying to connect a hidemyass VPN and in your instructions it says to toggle disable then add sign in details for hidemyass, then says to enable before connecting. That option isn't possible for me, can you help please?
Joe
