RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
Netduma-Fraser
Jan 14, 2021NetDuma Partner
You're using the VPN service which is the wrong feature. Click Hybrid VPN on the left hand menu of the interface - not in Settings, then you can continue with the instructions.
JoeFI
Jan 14, 2021Apprentice
Hi, yes that is what I was doing. I've sorted it now.
