RaleighEd
Feb 04, 2019Aspirant
Hybrid VPN Setup
Would like to set up the hybrid VPN with NordVPN. I have the OpenVPN file which I copied, as instructed, but my status is "disconnected".
I'm running on an iMac with the current MacOS.
Th...
qlofty
Mar 05, 2021Aspirant
Do you know if this feature will be coming to the XR1000. Only VPN option i see is under the advanced settings and that would apply to the whole network.
I would like to only apply it to specific devices.
