rothnd
Jan 07, 2025Aspirant
Hybrid VPN Torguard on Nighthawk xr500
Hello. Trying to figure out this “feature” of my router. Too many issues with it to even begin really. Has anyone gotten the Hybrid VPN to work? I’ve uploaded the connection config and applied it to c...
Netduma-Fraser
Jan 07, 2025NetDuma Partner
Please provide a screenshot of your HybridVPN page
- rothndJan 07, 2025AspirantI can’t. All my systems go nuts if that’s enabled so it’s not enabled. It said connected, it said only VPN this on that, what more can I say?
Ok. Ran a new test to get a screenshot. I have triple checked the protocol and port of the config. I have run countless whatismyip and portchecker.co checks and all show that this config does absolutely nothing in terms of the VPN connection. All checks show my regular WAN IP and that the supplied port (32400) is closed despite it being open on the VPN IP (through Torguard site).
Additionally, this is using the first os and OpenVPN v '2.4 and above'.
More findings.
I have a feeling I'm missing something here. Upon further testing when I have the mode of the Hybrid VPN set to 'Do not VPN these services' with an advanced setting of xxxxx port for all entries, my public IP *does* change to the VPN IP, however, that xxxxx port which is open on the VPN is closed/stealth with this mode active on the router.
Appreciate it if you can tell me what I'm missing!
- Netduma-FraserJan 07, 2025NetDuma PartnerThe port you've port in is not the port a website would use to determine your IP address - you essentially said have everything other than this specific port go through my normal connection.
Do NOT VPN these services will VPN the entire device if you have no services added.
