Marv-K
Aug 17, 2021Guide
hybrid vpn xr500 , connection problems / high ping
Hello, I have had problems with my Hybrid VPN for almost 2 weeks. I use OpenVPN (nolag vpn). I play on console (ps4). For several days I have had the problem that my ping is so high when I activate th...
- Aug 18, 2021
OK, but this is only happening when going through the VPN? If you disable the VPN, your ping is normal?
Marv-K
Aug 17, 2021Guide
I know no lag vpn is only compatible with pc, but you can also use the vpn on the modem via open vpn. It was a few days ago, the problem with the high ping has only recently been. I contact the support from the provider. I've been using open VPN (nolag vpn) for about 2 months and until 2 weeks ago it was fine. (50-80 ms ping). NOW 500-800 ms ping.
Netduma-Liam
Aug 18, 2021NetDuma Partner
What about if you try a different VPN server? It may be that the NZ server is under load and is causing delays.
- Marv-KAug 18, 2021GuideI did that of course, in general. The ping of every VPN server is 5-10 times * as high as before.
- Netduma-LiamAug 18, 2021NetDuma Partner
