Marv-K
Aug 17, 2021Guide
hybrid vpn xr500 , connection problems / high ping
Hello, I have had problems with my Hybrid VPN for almost 2 weeks. I use OpenVPN (nolag vpn). I play on console (ps4). For several days I have had the problem that my ping is so high when I activate th...
- Aug 18, 2021
OK, but this is only happening when going through the VPN? If you disable the VPN, your ping is normal?
Marv-K
Aug 18, 2021Guide
I did that of course, in general. The ping of every VPN server is 5-10 times * as high as before.
Netduma-Liam
Aug 18, 2021NetDuma Partner
